Tranny Problem?
Old 09-19-2007, 05:47 PM
bake90's Avatar
Default Tranny Problem?
Sometimes during normal shifting (sometimes from 3rd to 5th) I will go all they way over in reverse. I have gotten a little bit of grind when this happens but it obviously doesn't go in gear. Any ideas on what is wrong that is allowing this to happen. Thanks!
Old 09-19-2007, 06:45 PM
thesource's Avatar
Sounds like the reverse detent/solenoid is getting soft along with the shifter detents might be a little weak as well .
