Clutch swap on a 03 cobra T56
Ive done a handful of clutch swaps in a fbody t56 but im doing my buddies cobra and i wanted to know if u guys have any tips or anything im sure its pretty much the same thing. but just wanted to know exactly how that **** works with the ccable driven **** now that its not the hydraluics with the slave cylinder.
thanks.
thanks.
Its very basic and non adjustable in stock form . Personally I would install an adjustable cable , fire wall adjuster and quadrant under the dash . I also like to use a heat sleeve on the cable to reduce the heat on it from the headers .
As for adjusting it , take all the slack out of the cable and add just a little preload but not so much that the clutch slips on you .
