drill mod
Old 10-05-2007, 06:52 PM
99ls1bowtie's Avatar
Default drill mod
how far into the line is the restriction? ive recently put in a spec 2, and 01 slave cylinder and did the drill mod. but im not sure that i did the drill mod right. i was under the impression that the fitting going into the master cylinder was a restriction itself. so i drilled it with a 1/8th drill, but not too much metal was removed...felt like it was kind of pointless. but now that i think about it, it seems like i remember hitting something about 3/4 of an inch in. so is the fitting itself the restriction, or is it further into the fitting?
Old 10-05-2007, 09:50 PM
wrencher
wrencher's Avatar
Have you seen this b-4 an oldie but still a goodie
http://installuniversity.com/install...sity/index.htm
It's in the trans section of the install documents
Old 10-05-2007, 09:55 PM
lsp408's Avatar
if you drill the restrictor out, the drill bit will go pass 3/4" mark easy
