clutch line
Old 11-03-2007, 02:31 PM
LS1Birdy's Avatar
Default clutch line
im still at it with that stubborn clutch line that doesn't want to come out. i have the before and after pictures of me messing around with it. but i noticed today, that the trans is leaking. looks like brake fluid, so im assuming its coming from the slave cylinder. i loosened the bleeder valve earlier on in the week, im not sure if it is leaking because of that, or because i might have broken the slave cylinder....please help
Attached Thumbnails clutch line-before.jpg   clutch line-after.jpg   clutch line-picture-002.jpg   clutch line-picture-004.jpg   clutch line-picture-005.jpg
Old 11-03-2007, 03:31 PM
Toes's Avatar
looks like when you opened your bleeder valve it bled down to the bottom of your housing. clean it and check you reservoir. hows the pedal feel? assuming its bled. if the reservoir goes down then you got a leak
Old 11-03-2007, 04:02 PM
LS1Birdy's Avatar
well unfortunately i wont be able to check out the pedal just yet, trying to do the drill mod and got stuck on the clutch line before i can get it out.
Quick Reply: clutch line
