Slave Leaking after clutch install! need help fast!
Old 11-04-2007, 11:24 AM
EvilCamaroSS's Avatar
Default Slave Leaking after clutch install! need help fast!
We got my new clutch in and we went to bleed my slave which I installed last time around with GM part # 15046288 less than 12K ago. we took the spring off to change the throwout bearing, and put it back together and it wouldn't bleed we pressure bled it and now it's leaking near the middle of the slave... any idea why? I need to get the car back together today and advance auto parts has this slave in stock and i was wondering if it would be an ok replacement, I had the updated slave and master and this is the only slave they list for a 1998 camaro and they don't list any for 01-02 camaros
http://www.partsamerica.com/ProductD...pe=236&PTSet=A
any ideas?
Old 11-04-2007, 02:15 PM
hello?
Quick Reply: Slave Leaking after clutch install! need help fast!
