Stiff T-56
Old 11-16-2007, 10:23 AM
CK9887's Avatar
Default Stiff T-56
Its a 00 WS6 M6. Lately the tranny has been real stiff when its cold, very hard to get into gear. Its all stock except for a WS6 store short stick, the clutch was replaced about 15k mi ago. The clutch isnt slipping and grabs ok.
Usually after driving around for a few mins it will loosen everything up, but when its cold its almost impossible to get into gear.
Any ideas?
Old 11-16-2007, 10:36 AM
Jeep_junkie's Avatar
My 94 is similar too. Doesn't want to go into gear easily in cold weather. Everything feels real notchy for a few minutes until it warms up. I think it's time for a fluid change, but I wonder what the best stuff is to put in there??
Old 11-16-2007, 03:25 PM
CK9887's Avatar
Anyone?
Old 11-18-2007, 10:42 AM
Dex
Dex's Avatar
Mine is the same way it really hates the cold once warmed up its fine
Old 11-18-2007, 11:08 AM
ws66's Avatar
I like royal purple I put it in mine after I rebuilt it
Old 11-18-2007, 07:39 PM
thesource's Avatar
Usually its the thickness of the fluid but it hasn't really got cold down here in Texas this year . I would definately drain the fluid and use either Royal Purple Syncromax or regular non synthetic ATF Dex/Mer III in it . Its possible that someone put gear oil in it since its a standard and that would cause the issues you are complaining about . You could also have a slave cylinder going out on you as well .
Quick Reply: Stiff T-56
