Tranny removal question
Old 11-17-2007, 07:55 AM
S1LV3R's Avatar
Default Tranny removal question
After removal of the crossmember and tranny, does the rear of the motor need to be supported? I looked at the install university and didn't see anything about supporting the rear of the motor. All of the older vehicles I have worked on need the rear of the motor supported. Of course all the those had distributors.
Thanks in advance,
Larry
P.S.
This is an '02 camaro
Old 11-17-2007, 08:44 AM
purdueranger's Avatar
I put a floor jack at the back of the motor just to suport it. I put a block of wood inbetween the jack and the motor
Old 11-17-2007, 09:02 AM
blkbird's Avatar
I have some poly motor mounts and they help support it pretty good without being jacked up.
Old 11-17-2007, 09:44 AM
KillerZO6's Avatar
no it doesnt need it but, it wouldnt hurt to do it any way
Old 11-17-2007, 11:46 AM
whyte95ZRida's Avatar
The only thing I supported was the trans with a trans jack, until I was able to get if off the corroded guide pins.
Old 11-17-2007, 07:46 PM
8a8mfh's Avatar
The exhaust will hit the frame on the passenger side and keep it from coming too far down to damage anything.
Quick Reply: Tranny removal question
