Just finished my Ram Adj Master
Install wasn't bad and it fixed my problem of pedal stuck to floor.
I didn't bleed the slave after installing the hydraulic line back to the transmission due to problems getting a socket over the bleeder. Pedal seems a little light but the tranny shifts just fine.
The clutch pedal now sticks out further than the brake. Shouldn't I adjust it to be in line w/ the brake? I can't recall the exact position prior to the install. The clutch is still stock.
I just want to make sure the pedal isn't too far from the floor which seems would cause clutch to slip against the flywheel when engaged.
