clutch line questions
12 Second Truck Club
ok i found this https://ls1tech.com/forums/conversions-swaps/606483-clutch-line-conversion-fitting-solved.html so i have a question. i have some braided stainless line i got from work. not sure on the size but it says t3500-04 for a part number and it says "OP 3000 PSI" so i think its tested to 3000psi. at least the big green tag on it says test to 3000 psi. so question is will this line work? i found a -4 to -3an reducer to fit the clutch master/slave adapter. (incase its a -4an line) its pretty small in diameter. the line is for aircraft hydrolic equipment. so i figure it could handle a little clutch work. just didn't know if it was ok to use a -4 line with -3 adapters for clutch line.
is there a way to messure the line to know for sure its size? what is a -3 or -4an line equal to in inches? say 1/8" or what?
*EDIT* measured line at 3/16"
