GTO Clutch vs F-Body Clutch. Whats the diff??
Old 01-28-2008, 10:27 PM
hosspowerinc's Avatar
Default GTO Clutch vs F-Body Clutch. Whats the diff??
I know that the m12s and m6s are the same so why the different part number for the clutch and pressure plate? Do they use a different slave and/or TO bearing maybe? The reason I ask is I picked up a SPEC setup from an 05 GTO to go in my Fbody. Now the spec flywheel part numbers are the same for both cars, only the pressure plate is different so the LS2 flywheel doesnt factor in (in my case anyway). Anyone know if I can just bolt it in or ????
Old 01-30-2008, 10:55 AM
Hmm know one knows either? I guess itll just have to be a surprise!
Old 01-30-2008, 11:43 AM
Tough Mudder
Hilton's Avatar
I know. I know a LOT. Just don't feel like retyping all of it. Search under my name.
Old 02-08-2008, 06:55 PM
All I found was you swapped in a m12. I am keeping my m6, just have a gto clutch I got on the cheep.
Old 02-12-2008, 06:49 PM
Just FYI the 05 Gto pressure plate fingers are .200" shorter than the fbody. This can be fixed by shims or by using the gto slave.
Quick Reply: GTO Clutch vs F-Body Clutch. Whats the diff??
