clutch problems?
clutch problems?
I notice that my clutch pedal it feels little weird and when I push the pedal it stays down and it come back little by little. I'm assuming this is the slave cylinder. What do you think? and if it is what a good slave cylinder that will be durable? Thanks in advance!!
Sounds like you need to check for hydraulic leaks and bleed your system. There is a good chance that it is your slave cylinder. I would check out www.summitracing.com and get the GM slave/throwout bearing combo which they sell for $125. To do the slave you need to drop the tranny. This might be a good opportunity for a LS7 clutch upgrade.
