clutch hyd line needed
Old 02-19-2008, 08:18 PM
2manytoys's Avatar
Default clutch hyd line needed
Like it says I need the braided line that runs from the master to the slave. Mine is leaking just before the quick connect. Its seeping through the braided part. Maybe it got damaged during shipping. I don't want to have to buy a new master. Anyone have one laying around from a bad master cyl?
Old 02-19-2008, 10:27 PM
Kleeborp the Moderator™
MeentSS02's Avatar
For some reason, I think there is an o-ring in there if you punch out the roll pin...check that first just to make sure it isn't damaged.
Old 02-20-2008, 08:00 AM
2manytoys's Avatar
I cleaned everything up and got my wife to press the pedal. Fluid is coming from the line just behind the crimp on the quick disc at the slave.
Old 02-20-2008, 08:53 AM
Tough Mudder
Hilton's Avatar
I had a similar problem. I took the ends off and went to a hose store. They replaced the line for less than $20.
For local guys, Bearing Service & Supply
Old 02-20-2008, 08:54 AM
SladeX's Avatar
I think you can only get them with a master cylinder. Hopefully someone around has a spare they can send you locally.
Old 02-24-2008, 10:57 AM
2manytoys's Avatar
Anybody? I posted this in the parts wanted section also.
Old 02-24-2008, 11:30 AM
shoemike's Avatar
mcleod makes them, but they are expensive.
