Please help!! Spec stage 3 ?
Old 03-04-2008, 05:35 PM
2001AntiVenom's Avatar
Default Please help!! Spec stage 3 ?
I got a spec stage 3. that is the medal ring for that come with the presure plate? It looks like a spacer or something. do i need it?
Old 03-04-2008, 06:15 PM
DJB
12 Second club
DJB's Avatar
Yes you need it that is a shim for the slave.
Old 03-05-2008, 03:16 AM
blue98Z's Avatar
Did you not read the directions? It tells you where it goes and yes you need it.
Old 03-05-2008, 08:59 AM
SPEC-01's Avatar
2001 The ring you reference is meant to go behind the slave cylinder. There are instructions that discuss...the shim is sent in the same bag as the directions. Without the shim you will have a lower than normal release/engagement point. Please let me know if you have any further questions. Thanks!
Old 03-05-2008, 08:32 PM
um there was NOT any directions with my kit. sorry. and i figured out where it went when i pulled the master out!
ok thanks
