Pulling the trans for service...
Old 03-09-2008, 12:39 AM
67rsss's Avatar
Default Pulling the trans for service...
Okay, we are ready to send the trans to Six Speeds Inc. to get rebuilt. Reverse keeps popping out, and there is a minor leak at the input shaft. This is a 2002 LS1/T56 in our 67 Camaro.
What I am dying to know is can we just unbolt the trans from the bellhousing and pull it out, or do we have to pull the bellhousing also? There is not a lot of clearance for pulling the top bolts on the bellhousing, and I cannot for the life of me remember is the slave bolts into the trans or just into the bellhousing. That would make this job a lot easier, since we don't have to send the bellhousing to Six Speeds...
Old 03-09-2008, 12:37 PM
Red
Red's Avatar
If you are just rebuilding the trans and that's all, just unbolt the trans from the bell housing. Yes the Salve is bolted to trans with 2 10mm bolts or 2 8mm bolts--hope this helps!
Scott R.
Old 03-09-2008, 01:08 PM
hndakilr's Avatar
Scott R.
+1 the clutch swap sticky is all you need to check out. leave the bellhousing. 10mm for the slave
Old 03-09-2008, 01:51 PM
madclown's Avatar
BOLTS HAVE A 10MM HEAD BUT THEY ARE 6MM BOLTS......
Quick Reply: Pulling the trans for service...
