who has installed a spec stage2 clutch in their fbody?
i have a spec stage2 with a problem wondering what others have had this problem and how do you go about fixing it. the clutch disengagement is really low on the car. i have to stuff the clutch pedal into the floor to get the clutch to disengage. has anyone else had this problem? does adjustable master fix it or no? i did install the shim behind the clutch and it still is an issue.
