High RPM grind into 3rd gear?
I'm posting this for my dad. It's a 2000 WS6 with ~40k miles on it, LS7 clutch, new slave, ram adjustable master cylinder. The clutch disengages a couple inches off the floor and it shifts fine into every gear under normal or even spirited driving, but at WOT and shifts at 6k+ it grinds on the 2-3 shift. The 1-2 and 3-4 are fine. I'm guessing its the synchros but I wanted a 2nd opinion.
a few things can cause that, the clutch not fully disengaging, which could be a sign of the slave going bad( which new ones can do) or maybe a master going bad. worst case yes the syncro's could be going out 2-3 and that will cause it to grind.
