SPEC 3 Hop after 500+
Just wondering I'm now around 550 miles on new clutch, but still hops unless I give it gas (about 1200-1500 rpm). Is it just still not brok in or is this Spec's normal behavior?
Stock I was able to do a slow clutch release with rpms in 800-1000 with no problems.
This clutch is very grabby compared to stock. When I hit my 500+ breakin point, mine was doing the same thing. So I went out on a very spirited run through the country and on interstate. Did some launches and some high rpm shifts. Probably a good 30min run then went and parked it for the night. Hasn't done it since.
