New clutch: Pedal Wont move
Old 04-28-2008, 12:00 PM
BuffJoeyD's Avatar
Default New clutch: Pedal Wont move
Searching didnt find me what I was looking for...
Put in a new clutch , spec 2+ with flywheel. Put the trans back in in and went to test the clutch pedal out, and its hard stuck- can barely move it ½ inch ( thats just pedal spring slack )
Car had a crappy stock clutch, 16,000 miles, 2002.
I am thinking there is something wrong with the slave, the kit from spec came with a replacement TO bearing for the slave which I installed along with a shim.
Havent tried to start the car yet. Should the car be netural started while it is like this?
Old 04-28-2008, 12:06 PM
chuckyt1's Avatar
Did you double check the line? Make sure it's plugged into the slave.
Old 04-28-2008, 12:12 PM
BuffJoeyD's Avatar
I installed and checked the line to the slave. It would take pushing the quick disconnect back in to remove it.
Old 04-28-2008, 01:58 PM
PewterScreaminMach's Avatar
x2 on sounds like the braided master line to the slave. I would disconnect and then reconnect it just to make sure. Make sure it clicks in.
Old 04-28-2008, 02:01 PM
_JB_'s Avatar
I'm with these guys. Make sure it's pressed in all the way.
Old 05-12-2008, 12:45 PM
BuffJoeyD's Avatar
Thanks guys - the line going into the slave was clicking in but not making full contact. Replaced the line clicked it in , pedal works great!
Quick Reply: New clutch: Pedal Wont move
