clutch problems
clutch problems
Hey guys! just realized after I got my powergrip hd installed that you should NOT use the stock flywheel with these clutches is this true because I am having a hard time with no reverse (unless I turn the car off)and the other gears feel way stiffer that they used to with stock clutch? I have bled it 4 times and changed all hydros? Oh and the shop did say my stock flywheel was almost not resurfacable??
Sounds like you are not disengaging all the way. Might try a shim behind the slave to move the TO closer to the PP (check the measurements first). The clutch disk isn't going to know the diff between a stock and billet flywheel.
