T56 Rebuild "how to" write up
Old 07-07-2009, 01:09 AM
  #81
RestoRoc89's Avatar
There was no mention about checking endplay in this write-up nor was there any solution proposed for the 'special' tool required to check the counter shaft endplay specifically.
It's been a few years since I rebuilt my T56, but I remember having to assemble the gear shafts and case WITHOUT the shift forks/rail assembly to properly check the endplay (this is covered in the Tremec rebuild manual...so please excuse my foggy memory).
Anyways, you will need a dial indicator of some sort (I have a magnetic base as shown in the photos below), a shim kit (I replaced the bearings/bearing races and the endplay DID change slightly...I ended up needing slightly thinner shims) and the counter shaft tool (a glorified threaded rod). I had a machinist at work make the tool for me with the drawing provided by Tremec for free...but he figured it shouldn't cost any more than $50 for a machine shop to make.
Onto a few pictures:
Countershaft Endplay Tool:
Tool threaded into counter shaft through housing. You 'tug' on this and set a dial indicator to the end to measure countershaft endplay.
Example of dial indicator use to check mainshaft endplay:
An alternative version of the makeshift gear puller:
Kudos to the original poster for creating this 'how-to'. I took many pictures when I rebuilt my transmission, but I've never had the ambition to produce a 'how-to' article. At any rate, I highly recommend this as a DIY project as it was interesting and, in my case, yielded a very satisfying result.
Old 07-07-2009, 10:37 AM
  #82
the_merv's Avatar
Nice thread. I just tore mine down and it was pretty easy so hopefully it goes back together that way.
Old 07-07-2009, 03:31 PM
  #83
toy4x4's Avatar
Great addition RestoRock89, How long of pullers are needed? I need to get a set before I start this project and was wondering if anyone could tell me how long the ones they used were. I see a set made by OTC that are 15.5 inches of reach for $$$. I would hate to fork out that much if they are still too short. It looks like the ones pictured by RestoRock89 are close to 20 inches long???
Also If I use a cheapo set and mod them like that, will they still be adequate for pulling everything or will I need several diff types or sizes? Someone wrote about having broken 2 pullers and having to cut the gear off the shaft. I don't want to invest in a cheap set of pullers if they will not be strong enough or fit the gears and bearings correctly. I have a pair of cheap pullers somewhere but the hooks on the ends are huge. Are there any clearance issues with the hooks on diff types of pullers???
Right now the pulling of the gears and bearings are my only concerns everything else looks straight forward, perhaps pulling is not as hard as I am thinking?
Old 07-07-2009, 03:41 PM
  #84
the_merv's Avatar
I made a custom puller aswell..took the $40 Craftsman set and bought 2 pieces of 1" X 1/8" steel from lowes.. they are 36" long if I remember right.. well I took them and cut them inhalf, then drilled holes in each end and made extentions for the puller.
This is what I was modeling mine off of..it's pretty much the same thing and worked perfect. I have roughly $55 and about an hour of time in making that tool.
Old 07-08-2009, 07:52 AM
  #85
toy4x4's Avatar
Thats good to know, now I will have to find those pullers I have and see about making the extenders. But now I am confused about what needs pulling and what comes off easily. I was thinking that each gear had to be pulled off. But on closer look at this guide it appears I only need pullers for the Synchro hubs? Can some one clarify what is pressed on the shafts and what is easy to slide off?
Will I need one of these separators / pullers?
Old 07-08-2009, 08:22 AM
  #86
the_merv's Avatar
Those come in handy for the tight spots..I had to use them for them Gears right there, but everything else I was able to get with the Pullers I made.
Pretty much the Gears themselves will slide off, the Sliders need to be pulled, aswell as the Speedo Reluctor Wheel. Make sure that there is no Snap Rings in the way..and double check..cause if you try pulling with one inplace you will end up breaking something.
Old 07-21-2009, 10:12 PM
  #87
02cetransam's Avatar
very good info!! thanks!
Old 08-03-2009, 01:23 AM
  #88
harbaugh's Avatar
..bump
Old 08-12-2009, 05:21 PM
  #89
Gen414's Avatar
This type of puller (bearing spreader) is JUST about the only way to pull off the "end" bearings that I know of (countershaft #104 and #106 and mainshaft #22, in pic above, far right), well, without atleast mangling the crap out of 'em. Most rebuilds don't require the removal/replacement of 'em, but every now and then (like the rebuild we just finished up the other day), had to. So, keep that in mind...as teh bearing spreader like that is hard to locate.
*****BUMP*****
Old 08-14-2009, 04:48 PM
  #90
blu byu EH's Avatar
bumb.... make this a sticky
Old 08-17-2009, 08:04 AM
  #91
Kus99TA's Avatar
I started on my rebuild over the weekend,I did the billet keys and bronze pads.When the main case is put on it is very difficult to turn the shaft by hand is this normal?Does it have to do with the fork pads being metal on metal and no fluid being in the tranny yet?
Old 08-17-2009, 08:56 AM
  #92
Slo_240sx's Avatar
you should still be able to rotate it pretty easy. Check your bearing preload and that its not engaged in a gear.
Old 08-17-2009, 09:42 AM
  #93
the_merv's Avatar
Yea it sounds like it's shimmed too tight. Did you check it with a Dial Indicator?
Old 08-17-2009, 01:30 PM
  #94
Kus99TA's Avatar
Everything looked great so and there were no shs in it when taken apart so we left it. Even with the case bolts loosened it's still tight.
Old 08-17-2009, 01:31 PM
  #95
Kus99TA's Avatar
FYI......shs=shims
Old 12-28-2009, 03:18 AM
  #96
94camaroz28lt1's Avatar
This is a great article http://www.ls2.com/forums/showthread...&threadid=1877 how ever it won`t let me ask a question there? So I will ask it here also a great write up!. I have heard from a couple of transmission shops that you can "sharpen" the "dog" teeth on the transmission gears. they are shaped like a coffin, and are what the syncro slides on to to lock the gear to the main shaft, they are supposed to come to a point to help the sychro slider, slide onto the gear, however most of my gears 1, 2, 3, 4, 5, and reverse are all "rounded" according to the transmission shops. They suggested using a 3m "cookie" cutter mounted to a high speed air die grinder, or dremel, to sharpen each dog to a new point? Will this work has anyone heard of this?
FYI I have the entire transmissions apart, I have most of the special tools needed for the rebuild.. pullers, 12ton shop press, dial indicator, ec..
-I am also looking to make the special tool needed to check the cluster shaft end-play, there is a nice drawing in the manual, at the end, I can`t see why it couldn`t just be a length of M12 ready rod? or is there a reason the middle of the tool has a round shank on it? Thanks guys! Any help is appreciated!
Old 12-28-2009, 09:26 AM
  #97
01ssreda4's Avatar
Old 12-28-2009, 02:32 PM
  #98
nice set of pictures! I don`t see any text with them though? Did you have a question or where you trying to show the dogs on the gear for me?
Old 12-28-2009, 07:36 PM
  #99
01ssreda4's Avatar
Thats an MN12 GTO T56. Just posted some pics in case anyone was searching threads
Old 01-08-2010, 03:45 PM
  #100
DeanJ's Avatar
This needs to stay up top for the DIY guys. Dean
Quick Reply: T56 Rebuild "how to" write up
