Help With Problem!
Help With Problem!
I have a spec 3 clutch and billet steel flywheel
Everytime I take off from a dead start you can feel something hitting when the clutch begins to engage in the clutch pedal...Sounds like something is rubbing..Once I'm in gear I can only feel the viberation in the pedal when I the clutch first enganges shifting into a higher gear..I'm going to pull out the trans and check everything over tomorrow..Does it sound like the throw out bearing or pressure plate??
