need clutch help
Old 06-11-2008, 02:25 PM
cabel1's Avatar
Default need clutch help
Well I was driving around today and the clutch pedal just kept getting higher and higher and by the time I got home I basically have no clutch left.
I am running a Ram-910 right now. I assume I ate it up from street driving it. My 60's have been falling off this year and I guess I found out why.
I need to know what you guys think I should run for a clutch that will hold up.
Cam only 346, TRex, stock intake, stock heads, Six Speeds T-56, 9" 4.30's, UMI suspension, runs 11.90's dumping the clutch at 6K with the tires off the ground. It is a weekend warrier so it doesn't see tons of miles but I am planning on adding more power in the future.
