are there any write ups on how to remove tranny
Dont know how to post link but if you click on manual trans section it is the fifth sticky from the top "Clutch swap and trans removal".
One thing that is not mentioned is that if you would like to avaoid bleeding the slave you can pull the trand back a bit and sneek a 10mm ratchet wrench in there and just unbolt the slave rather than removing the hydraulic line.Good luck!
