Newb M6 questions
Newb M6 questions
I'm having a hard time downshifting 3rd to 2nd and hitting reverse. Is it time for a rebuild or is this a clutch issue?
If I do a rebuild does it makes sense to replace the clutch while I'm at it? I think its stock.
Thanks in advance.
Thanks in advance.
That's a strange problem given the shift pattern. You are coming back and to the left to hit second whereas reverse is to the right. In addition, reverse is locked out. I'm thinking you just need some practice unless I'm misunderstanding what you are saying.
