Tranny Getting HOT?
Tranny Getting HOT?
k well after I drive a bit, the entire tunnel over the tranny gets extremely hot! from under the radio, the sides of the tunnel, inside the console.... so what can I check/do for this? fluid is good and clean and full...
The bellhousing conducts engine heat to the transmission. On the highway I sometimes rest my hand on the shifter below the ****. Can’t do that in hot weather. The temperature is probably not as high as it seems. Not to worry, it is normal with these cars.
