help with a problem
help with a problem
ok it this only happens in third gear when i shift in to it and let out the clutch some times it feels like your letting off the clutch really really slow but the rpms or nothing dont jump like it would if the clutch was slipping. it just like baslicly lugs you and then in like 2 seconds wants to go but it doesnt do it all the time. idk if its with the trans the clutch the hydralics or the throttle . thanks for the help.
its hard to explain its like the engine is lugging its self kind or like your letting out the clutch really really slow.like it will throw you forward kind of like when you tap the brakes hard. and its not like im shifting it wrong or cant drive because it only happens in 3rd gear will not happen in any other gear.
