how do you remove/install a new Slave cylinder?
It helps if you gently push inward on the hose itself while pushing the white plastic retainer sleeve. When the white sleeve is fully depressed, you'll be able to remove the hose.
AutoZone and Advance sell a Bendix replacement slave and throwout bearing assembly for less than $100 that has a good reputation with the GTO guys, comes with the bleeder and hydraulic fitting already attached so it's ready to install.
