Clutch Help!!!!
Clutch Help!!!!
my clutch pedal with stick near the floor, and the clutch release is more like an on/off switch. clutch still seems to have plenty of grab. is this the clutch gone bad, or is it the clutch slave cylinder? any input will be greatly appreciated.
thanks in advance
karl
thanks in advance
karl
wrencher
Sounds like you have hydraulic issues. Read the sticky threads at the top of the forum.
Check the fluid you might improve it by just bleeding it out.
Otherwise you may have master cylinder issues or possible slave.
