Clutch or Trans
Clutch or Trans
I've noticed lately that when I jump on the throttle I can hear a chattering noise coming from the trans tunnel. Should I be looking at a bad clutch or something internal in the trans. I have 45,000 miles on the original clutch( not driven hard).
LS1TECH Sponsor
Does it only do it when you accelerate from a low rpm, or any rpm? Do you feel any vibrations, in the shifter possibly?
Without a little better description its tough to say, it could even be something like a broken transmission mount allowing the transmission to rattle against the floorboard/tunnel or an exhaust pipe against something as well.
