LS6 pilot bushing different/longer than LS1 ?
Old 08-14-2008, 04:22 PM
85MikeTPI's Avatar
Default LS6 pilot bushing different/longer than LS1 ?
I'm helping a friend retrofit a CTS-V T56 behind a LS1 motor in a '70s chevy pickup. It looks like the CTS-V trans has about 1/2" top 3/4" shorter input shaft than a LS1. Did they use an extended pilot bushing on the LS6 motor?, and would anyone happen to have the p/n for it if so?
TIA
mike
Old 08-17-2008, 07:54 PM
85MikeTPI's Avatar
Anyone ever look at an LS6 pilot? I mocked up everything tonight and the input shaft is exactly 1/2" shorter on the CTS-V. Can the LS1 use a McLeod extended pilot bushing?
Old 08-17-2008, 08:53 PM
LS1TECH Sponsor
Jonathan@Tick's Avatar
Check this thread out that I replied in a little while back:
https://ls1tech.com/forums/showthrea...825&highlight=
I bet the cts-v engine uses this bearing: http://i90.photobucket.com/albums/k2...8/DSCI0034.jpg
It seats into the area of the crankshaft normally used to locate a torque converter in an auto application. That would make it necessary for the input to be slightly shorter than a normal LS1 t56.
Quick Reply: LS6 pilot bushing different/longer than LS1 ?
