Will 02 Z06 clutch work in 01 WS6?
yes it will work and yes it has more holding power. It is rated @ 400HP (crank hp). Naturally it can hold a little bit more then that. If however you're going with a high HP build, they're much better clutches then this. This is good OEM replacement good for bolt-ons
