Help A Noob-Stripped Threads
I was installing my new Textralia pressure plate and I cross threaded two bolts. They're not that bad, but I took it down anyway. One bolt hole is screwed up at the beginning and the second is in the middle of the hole. The bolts wont thread into any hole on my flywheel so they are shot. What should I do about the two bolt holes on my flywheel? I'm so mad, I really want to get two new bolts and just torque them in anyway.
from the sounds of it you just bunged the bolts for the most part. IMO first try and retap the holes and get new bolts. if it feels really loose then go bigger but you prob wont have to.
Thanks for the replies. How do I know what size tap to use? I've never re-tapped anything. It's a Textralia X-grip, and the bolts came with it. The bolts look the same as the ones that came off of my Spec pressure plate, but the thread count looks different. I put up some pics of one of the bolts. I couldnt get a good enough pic of the bolt hole on my flywheel. Please click on the pics if you want to see a larger view. Thanks.
