T56 questions
Old 09-07-2008, 01:52 PM
OutToWinPAHC's Avatar
Default T56 questions
I have a LS1/6 setup in my Nissan 240SX using a built TH series trans. I want to swap it over to a T56. I found a really cheap C5 t56 that needs a rebuild.
I know they are rear mounted on those, so what would I need to mount it to the motor? I would assume the bellhousing and tailshaift from a F body but I'm not sure.
How much is a typical rebuild on these?
Old 09-07-2008, 02:20 PM
LS1TECH Sponsor
Jonathan@Tick's Avatar
Theres really nothing about a c5 tranny the same as an f-body unit. The mainshaft is longer, the front adapter is different, all the gears are different, the shift rail/linkage is different because it used a fron exit shift linkage on the vette, etc.
Just get an f-body transmission. If you find a deal on one of those that needs a rebuild, expect to pay $900 for something like our level 2 build: http://www.tick-performance.com/tick...ackages/fbody/
Old 09-07-2008, 02:51 PM
Well thanks for the info, rather then rebuild I think I'll just buy a new unit.
