Spec Aluminum pressure plate?
I did a search and not much info came up on the Spec aluminum pressure plate, is it worth purchasing this for the extra $200?
i have a alum spec flywheel and need to order the clutch asap. going with the Spec 3+ and curious if i should try the alum PP too but worried if it will be a not-so-smart move considering i have the alum flywheel and no A/C (im thinkin' motor will be zinging to the moon already)
duties for the car is not so much for drag but all-around purpose drives, RR, and autox.
\\thanks
\\thanks
come on guys, i need opinions...
anybody see any negatives that this may bring up, or is it all benefitial?
