What do I grease?
What do I grease?
On a 94 Z28. About to stick the trans back to the motor, but I have no idea what I should be greasing. I don't want to wreck the new clutch/pp.
Read both the Haynes and the Chiltons, um not a very good description in either.
So yeah not sure if I lubricate the inside of the pilot bushing with anything, the input shaft, throw out bearing, clutch fork, have no idea, help is much appreciated. -Corey
Well I used some lithium grease on the input shaft, used some synthetic grease on the tbolt, fork and the surface the fork works on. If wrong there is still time to correct me as I'm now researching on how the hell I put the trans back to the motor and attach the fork. I'm perplexed.
