Indianapolis engine shops? Recommend a good one.
I am getting ready to go through my 2000 ls1, put in a new cam, push rods, lifters. Before I pulled the engine I was getting a tick above 1800 rpm after bouncing the red limiter by accident. So I wanted to have the bearings checked out on everything and make sure everything is how it should be inside.
So I could probably do all this myself but have never assembled an LS1 before, I want the block and heads hot tanked so they are clean so its going to have to go to a machine shop either way. I will probably do the springs on the heads and install the heads, lifters, rods..ect. but I would like to find a place to go through the block, replace any rings/bearings necessary, hot tank, clean the surface for the heads, and install the cam.
Let me know where you would go.
I am on the south side of Indianapolis, and would like to stay near the city.
