Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
help me clear an ses code please
Old 06-08-2006, 04:17 PM
kozak's Avatar
Default help me clear an ses code please
can any one help me clear an ses code. it popped up after i put my new lid on and i didn;t put a hole in the lid for the temp sensor. today i put a hole in the lid and put the sensor and gromit in now i need to clear the code. any help would be appreciated.
Old 06-08-2006, 04:23 PM
Avalanche's Avatar
Try unplugging the battery and plugging it back in, that'll reset the computer. If that doesnt work you probably damaged the MAF when you did the Lid.
Old 06-08-2006, 04:44 PM
SDB
SDB's Avatar
go to a local autozone or advanced auto, tell them what ou did and you merely need to have the code dleared. SOme will tell you there not allowed to do so, but if you ask nicely, most will. Its always free.
SDB
Old 06-09-2006, 01:10 AM
kozak's Avatar
yeah, battery thing worked, thanks alot. is that a bad way to do it or is the battery disconnect ok.
Old 06-09-2006, 03:19 AM
Luna's Avatar
the right way to reset the pcm is key on and pull the PCM IGN and PCM BATT fuse for like 5-10 mins. Then turn key off, put fuses back, and start it up.
But the battery will USUALLY work
Old 06-09-2006, 09:16 AM
Avalanche's Avatar
np I do what I can... Ah a hard day's work complete... Im off to take a nap at work.
Quick Reply: help me clear an ses code please
