01 WS6 dyno custom cam and bolt ons
*NOTE* Videos are on facebook, will need an account to view
My car putting down 443whp on a Mustang dyno through a TH350 with 3600 stall.
http://www.facebook.com/video/video....subj=814979725
Short clip of a race against my buddies 13:1comp 2liter integra built by King Motorsports with annoying girl screaming at the end
Thanks, its completly stock bottom end
installed and done:
LS7 LIFTERS
Livernois .690 VALVE SPRINGS
241 HEADS 5 ANGLE VALVE JOB, MILLED .030, MILD PORT WORK
COMP CAMS (237 INT 244 EXH .610 INT .644 EXH 112 LS)
TSP 7.4 PUSHRODS
8.8 PLUGS WIRES
PORTED MAF, THROTTLE BODY AND LS6 MANIFOLD WITH SLP AIRBOX
PACESETTER 1 3/4 FULL LENGTH HEADERS
EXHAUST 3" Dumps
Transmission installed with the following:
TURBO 350 WITH 9 INCH TAILSHAFT.
HUGHES TRANS RACE CLUTCH KIT
HARDENED DRUMS
CHEETAH VALVE BODY
HUGHES 3600 NITROUS 10 INCH CONVERTER
B&M SHIFTER
HUGHES SFI FLYWHEEL
HUGHES LS1 CONVERTER SPACER
Interior has the following done:
6 POINT ROLLBAR
5 POINT HARNESS
Rear end:
STOCK 10 BOLT
3.42 MOTIVE GEARS
YUKON AXLES
AULBURN CONE POSI
ALUMINUM COVER WITH DRAIN
CUSTOM Z-BAR SUSPENSION WITH TORQUE ARM DELETE
installed and done:
LS7 LIFTERS
TSP 7.4 PUSHRODS
8.8 PLUGS WIRES
EXHAUST 3" Dumps
HARDENED DRUMS
CHEETAH VALVE BODY
B&M SHIFTER
HUGHES SFI FLYWHEEL
6 POINT ROLLBAR
5 POINT HARNESS
Rear end:
STOCK 10 BOLT
3.42 MOTIVE GEARS
YUKON AXLES
AULBURN CONE POSI
