Livernois Motorsports LS3 Big Bore Block Sleeving Demonstration
Old 12-15-2012, 12:40 PM
LivernoisMotorsports's Avatar
Default Livernois Motorsports LS3 Big Bore Block Sleeving Demonstration
Below is a video showing Livernois Motorsports machining an LS3 block and installing big bore sleeves.
This is an option for all Livernois Motorsports builds or customer supplied LS blocks.
Thanks for looking!
Regards,
Rick LeBlanc
Old 12-16-2012, 01:32 PM
RaggedRides's Avatar
At this point is one block as good as the other as far as LS2, LS3 and LS7 pieces go? Also, are the 6.0 iron blocks on the same boat?
Old 12-16-2012, 05:07 PM
89gmcs15's Avatar
What's the price in this work?
Old 12-17-2012, 05:47 PM
RickClarke23's Avatar
Please pm me a price for this on a 6.2 block.
Old 12-18-2012, 02:48 PM
Yes, LS2, LS3, and LS7 blocks are all good. We don't do the iron block, because after you remove the factory sleeves, there isn't much material left. You could run a wet sleeve with an iron block, but we prefer the dry sleeves.
Pricing for a dry sleeved, bored, decked customer supplied block is roughly $1,500.
PM on the way.
Thank you,
Rick
Quick Reply: Livernois Motorsports LS3 Big Bore Block Sleeving Demonstration
