New edge for my truck!!
New edge setup
Hey guys I just got an EDGE programmer for my F-150 and this little toy is awesome!!! It has 4 settings, 0-Stock;2-trans only,3-Tow,4-performance. It also can display four gauges at once. It'll show engine, temp, spark, oil, temp, MPG, pedal position, variable cam timing, RPM, torque%, Engine load, and a bit more. You can also customize any tune, you can change spark, shift firmness, shift RPM, WOT shift, WOT fuel, Gears, tires, and lots more. It also came with a mounting pod that matches the truck perfectly. Install time was 10 mins. MAX I wish they made these pupies for cars. I know they have chip, tuners, etc. but the display is worth the money by itself This thing only cost 339$ with free shipping Heres a pic of it in my truck showing the display. You can also change the display b/w green, blue, red, and mix the colors to a certain color of you choice. It also has a built in 0-60 and 1/4 mile timing test for your pleasure and its pretty accurate. It comes with a software program to where you can store info about your truck. It will produce an mpg chart at however many RPM's graph and so forth!!!! It also has a 1/4 calculation to give you an idea about how much hp and so forth your making, sure its not accurate but from some post who tried it and matched it to a dyno say its almost exact, + or - 5/10 hp. The only down side is that the damn program isnt compatible with MAC computers which kills me.
