low oil pressure
low oil pressure
So I installed a brand new slp oil pump after my stock pump went out. No it's not a pinched o ring, was installed correctly. Although the pressure is a little better it's still very low when it warms up.. When driving steadily at 70 or so it's at about 11-14 psi.. and when i romp on it, it doesn't move passed 35 psi. No heavy ticking sounds but enough to hear their could be a problem. Sounds a bit like it's not getting oil to the top end or at least enough. Lifters have anything to do with oil pressure? Crank bearings? I really could use the help. And yes I have checked and bought a brand new oil pressure sending unit. I'm using a K&N oil filter. I also switched oil from mobile 1 synthetic 10w-30 to royal purple 5 or 10w-30
LS1Tech Administrator
Received 1,493 Likes
Sounds like there might have been some internal damage done when the previous pump failed. Looks like you've gone over the basics of what the simple fixes would be, but still have seriously low pressure.
I'd probably consider getting an oil test done and see what trace elements might be present and pointing towards possibile damage.
when i romp it my car has 70lbs and when its warm it has 40 so id say something is definantly screwed up, try some 20W50 and see what happens and maybe put some lucas additive, i agree with the guy that said get an oil test done
My buddy is having the same problem and I suggested to him to do the same thing. I know the pump is installed correctly because I have personally installed it three times to double check that the o-ring is not pinched. Have you put a mechanical gauge on it?
