New to LS1 Tech..a few questions regarding ls1's
Hey guys
Im in the process of deciding where to take my 78 Trans Am build. Im trying to decide where i want to go with my engine. I have a Pontiac 400 in now and its not to bad, prolly around 350 hp. At first i was sure that i was going to put a forged internal 455 with a roller cam hoping to make around 500+. Then I saw an ls1 swaped 77 trans am and , and now im not sure if want to go with the 455 or a modern ls series motor . My questions are regarding the strength and durability of a stock ls1. Im trying to watch my money as I do my project and Im looking for the best hp for the $. The 455 is appealing for the power that comes from the cubic inches but its expensive. Ive seen full running ls1's for far less then the 455 short block i had planned. Could an ls1 make 500+ with stock internals and what kind of money is needed to get it there. Also there is an "ls3" for sale near by, how can i tell its an ls3 and not an ls1?
Thanks Mike
Thanks Mike
its possible but hard to make 500 to the ground. takes just about all the best parts and a heavy cam. The ls3 is diff in so many ways. cam sensor location knock sensors etc.. look for rectangle port heads and for the ls3 head casting # in the search. 500 in an ls3 is a cam swap away.
I have been building pontiacs for around 30 years and it is MUCH cheaper to make big power with a Gen III/IV setup no doubt... It should be plenty dependable/ drivable too...
My 403 in the works should make 500+rwhp (a4) and run easy 10's while having DD manners. To top it off the EPS/Comp marine lobe cam should be much easier than my current XFI/X-ER cam and provide for a relatively trouble free valvetrain. These motors are better in almost every way to the old stuff. This coming from a guy who built 3 Pontiac 400's from 79-83... and has experience with a couple 455 builds with friends....
Pickup a motor PCM and harness and you are well on your way. You can make almost any tranny work with fairly minimal expense/mods....
Edit: BTW my cars were 68 GTO,77 and 79 Birds.. To this day the 77 was the favorite I ever had.. Was quick as lightening with ported heads, forged internals, Edelbrock IM, cam, 750 DP, sidepipes, etc... I think it was my fave cause in addition to the raw HP it had Rancho springs , bars and shocks that I could scare the **** outta people with and about sling them out the window..
