Cleaning an engine
Try to keep direct water/pressure off of the PCM and coil packs, Simple Green and similar products work great on most parts, but will haze aluminum. If you dilute the mixture with water 50/50 then it won't be as bad, and you can always use an aluminum polish to clean-up the front (flat) part of the heads, along with the AC condenser and other misc aluminum items. Don't know if it's the best way, but it's what I do and my engine bay looks great.
