valve cover bolt torque
Old 08-25-2010, 07:09 PM
yan2947's Avatar
Default valve cover bolt torque
Couldn't find the actual torque value for the 4 bolts on each valve cover - I have a 2002 LS1 Camaro.
Any help would be appreciated. I looked on the how2ls1.com site at their specs but didn't see this one.
thanks!
Old 08-25-2010, 07:11 PM
yan2947's Avatar
Unless of course its the valve rocker arm cover bolts - 106 lbs? - same as valve cover?
Old 08-26-2010, 09:22 AM
thunderstruck507's Avatar
I just tighten them by hand with a small ratchet, just snug don't go overboard on them
Old 08-26-2010, 09:41 AM
yan2947's Avatar
Thanks thunderstruck507. On the LS1Howto.com torque spec it has:
Valve Rocker Arm Cover Bolts - then it list the spec as 106 lb in
first of all is that the same as the valve cover?
and second the 106 lb in is that the same as 8.3 ft lbs?
I tightened them to 8 ft lbs. Thats not too tight?
thanks again!
Old 08-26-2010, 04:43 PM
djfury05's Avatar
snug should do it.. you are just trying to get a good seal with the gaskets.. you are not trying to keep immense clamping force on it
Old 08-26-2010, 05:28 PM
yan2947's Avatar
thanks!
Quick Reply: valve cover bolt torque
