Rear frame? Im new, and dont know much.
my rear frame is bent downward from an accident, is there a better way to fix it than, soldering a new one on, like bending it back somehow? Just trying to increase my knowledge.
Well first of all I would take it to a collision repair facility and have them look at it. Second of all you can not solder that sort of thing back on. The only thing soldering should be used for is wiring. I am assuming you meant welding when you said soldering.
First off F-bodies don't have a frame. They are Uni-bodies (the definition being that all the components of the drivetrain) If the rear end is bent downward then there is some serious work to be done. Might be able to pull it out with a frame machine and a very experienced bosy tech. Otherwise youre lookin at welding a lot of replacement panels on.
