in line, or in tank fuel pump?
I'm putting a 5.3L into my CJ7. I'm still pretty green to the LSx platform, so I have a few questions. I planned on running a walbro 255 pump in-line,to a corvette filter /regulator (p/n wix-33737) then a return line from the fuel rail to the tank. simple right?
Recenetly, a friend told me I need a pump in tank, to feed the walbro external fuel pump. his justification is the in line pump is designed to push the fuel out at XX psi, but not "pull" it as well. can anyone confirm or deny this?
thanks, Kyle.
thanks, Kyle.
I have seen systems that require a intake pump to push fuel to a in line pump so you friend can be correct, I am not 100% sure if your setup needs the dual pump setup but some do require it.
fuel cell is mounted behind the seats, so keeping it below the tank shouldnt be an issue. The gravity feed is a good point. protection while off-roading should be no problem either, I would rather place it in-line in a convienent, well protected spot, so I have the ability to change it on the trail, if need be.
thanks for the tips guys.
