LS1 N/A Intake Advice
Old 12-20-2011, 03:38 PM
sar795's Avatar
Default LS1 N/A Intake Advice
I have a 1998 Formula, A4, N/A with SLP cat. back. Looking to upgrade my intake for better low-mid range performance. Any suggestions?
Old 12-20-2011, 04:00 PM
TransAmWS.6's Avatar
You could get an LS6 intake, but honestly you will only see maybe 5-10rwhp at the most on a stock application, I would say. On a stock-ish car, you're going to see more gains if you just work on opening up your exhaust.
Old 12-20-2011, 04:13 PM
sar795's Avatar
I plan to change the exhaust, put I would like to know which intake is better, LS1, LS2, LS6, LSX? Which throttle body 78mm, 82mm, 90mm?
Old 12-20-2011, 04:17 PM
777's Avatar
How much money do you want to spend. The best value would be an ls6 intake used from someone on here.
Old 12-20-2011, 04:23 PM
sar795's Avatar
under 1000 if possible
Old 12-20-2011, 04:39 PM
1gt2nv's Avatar
lid, ported tb, ls6 intake, chrs 1313 ram air!
Old 12-20-2011, 04:46 PM
RedRocketZ28's Avatar
For a grand you could pick up a lid, LS6 intake, some BBK LT's, have your TB ported and still have over $200 left over.
Old 12-20-2011, 04:57 PM
1gt2nv's Avatar
Then the $200 could get him a Frost tune.
sar795's Avatar
Is it better to port than go with an 82 or 90mm ?
Old 12-20-2011, 09:00 PM
Ballinonabudget's Avatar
For your build, yeah ^^
Unless you get heavy with the mods and do head/cam you don't need a huge throttle body. It will hurt low end more than help it.
An LS6 intake, LT headers, ported TB, lid, and tune will net you a pretty big power increase
Old 12-20-2011, 09:48 PM
garygnu's Avatar
also look at a BBK or similar type intake ,$300 or less used..a ls6 intake is better the a ls2 intake.you can find used fast 90/92 mm intakes for 650 or less used.they is a thread about ls intake testing , do a search for it.
Old 12-21-2011, 07:53 AM
777's Avatar
BBK is a useless intake over an ls6 intake. I would get an ls6 or a used fast 90/92mm if you can find one for a decent price. Ls6 being much cheaper and the fast only gaining ~10rwhp over the ls6. Keep in mind ls6 is just bolt in (minus the coolant stuff, cheap though) Fast 90/92 you will need new fuel rails and throttle body which can add up to as much as the intake.
Old 12-21-2011, 08:31 AM
sar795's Avatar
thanks.
Old 12-21-2011, 06:36 PM
00redta88's Avatar
Hey man i have a 00 formula and live in chambana as well! Nice to see a local for sure. +1 on ls6 or pref fast 90/92
Old 12-21-2011, 07:27 PM
sepsis's Avatar
I've searched for a Fast 90/92 or 92/92 but I haven't found any for sale.
Old 12-21-2011, 09:48 PM
garygnu's Avatar
bbk and weiand intakes can keep up to a ls6 intake,studderin dyno tested them..with a fast 78/90/92 intake you can use your stock fuel rail and injectors ,but you would need bigger injectors if you are making 420+rwhp.
Old 12-22-2011, 08:35 AM
udienow's Avatar
This...
And dont get LT's... if you want low-mid range performance, LT's actually lose down low though they make a lot more up top. The other reason I wouldn't get LT's is cause of your cat-back. I assume its a SLP LM.
Old 12-22-2011, 08:54 AM
82cetuner's Avatar
dont waist your money on a fast 92/92 you wont see a good gain on a all stock motor with stock exhaust.
if you have a grand to spend do yourself a favor, get a good lid, ls6 intake, port the TB get a smooth bellow and spend the rest on opening up the exhaust.
your biggest bolt on gains to be had will be long tube headers. I know if I only had a grand i would start there.
dont get caught up into I gotta have the best intake to make HP, thats ricer mentality.
just to prove that i value my own words I run a LS3 intake on my 418 LS3 making over 600hp, its not worth 1000 dollars to me to make a extra 10rwhp right now with a Fast 102, id get a 150 shot first
Old 12-22-2011, 08:57 AM
82cetuner's Avatar
why would you say not to get long tubes? I have seen plenty of dynos where a set of longtubes made more power threw the entire power band over shorties and midtubes.
true there may be some torque loss but alot of the midrange loss comes from people slapping 1 7/8 headers on small cube motors thinking thats the best thing to do. 1 3/4 headers wont lose very much torque if any.
Originally Posted by udienow
This...
Old 12-22-2011, 09:14 AM
82cetuner's Avatar
you didnt look very hard LOL
https://ls1tech.com/forums/parts-cla...re-things.html
