Help Please!!!
Help Please!!!
hey guys i just ran into a nice chunk of change 3 g's, and i wanna go faster,of course. my mods right now, :
2000 Camaro SS A4
3.73's
home porting polishing maf and tb
all free mods
lid
bmr panhard
bmr lca's
Now this is what im looking for, 400 rwhp n/a, 500 w\ n20
i dynod with what i have now at 326hp and 339 tq
i drive my car almost every day probably around on average 15 miles a day, sometimes ill go on 150 mile trips, occasionaly.
now my idea to get there was:
pacesetter lt's no cat y pipe
3" cutout in I pipe,keeping stock cat back
MTI SSf 3500 or sf3000 (Im a little worried about going with the 3500 because i dont know if it is very streetable, plus im not totally understanding of the stall speed deal, if iam at a red light and am driving normally when i start to move am i not really going anywhere till im at 3500rpms? i dont understand the concept.)
GM Hotcam( i know its not the best but im looking for a little lopey idle, and i wanna be able to spray 100-150 shot. Also when i do a cam swap what else do i need to get it done?springs retainers etc...?)
Hand porting and polishing and cc the chamberson stock heads( my dad has sone this before so i should be ok with that! what kind of gains should i see?)
NOS or TNT or any other dry application(i need obviously the convertor and cam to work well with n20)
Walbro intank fuel pump (What size, or do i even need one?)
30# ford injector (needed???)
Lowering the rear end 1" (to try and get some traction)
15x10 Nomad II's (jegs and summit )with M/T et streets(will those rims fit, also what size tires are best??)
Ls1 Edit(what should my...Shift points,and tuning for n20. Is there anything else that should be done?
Is there anything you guys think i should change, i know alot will say different cam, so im open for suggestions, IM open for ANY suggestions and thoughts you guys might have. ive been researching this stuff for weeks now but theres just too much stuff to think of and its getting a little confusing so i figured i would ask you guys, after al ya'll are the experts.
Thanks guys and gals
Russ
2000 Camaro SS A4
3.73's
all free mods
lid
bmr panhard
bmr lca's
Russ
You have questions that cover a number of different areas. Probably best to ask each question in the area of that subject. Example, your torque converter question would be best in the Automatic section. N20 questions in the N20 section.. etc.. Do a little reading, and using the search feature in each section can help alot.
2000 Camaro SS A4
3.73's
all free mods
lid
bmr panhard
bmr lca's
Russ
2000 Camaro SS A4
3.73's
all free mods
lid
bmr panhard
bmr lca's
Russ
LS1Edit - Always a good investment
Tq Converter - YES & YES, and I think you mean TCI not MTI
Cam - if it were me I would go a little bigger on the cam, but still make sure its good for the spray
Nitrous - sure, its usually a preferrence
Wheels & Tires - I do not see those wheels you have listed in my JEGS catalog here, but maybe its because my catalog is not the newest one. Are these street wheels or more along the lines of light weight drag wheels? Tires: whatever you need to hook, at least an ET Street or I actually prefer Hoosier QTPs.
As far as the other items you listed, i dont have muct expertise in that department, maybe someone else will chime in on those. Hope I have helped some. Good luck on your modding
