circle track questions quick ish
Old 05-15-2013, 02:03 PM
ToxicWS6's Avatar
Default circle track questions quick ish
so i thought i could google this info and find it fairly easy but havnt had any luck, i plan on runnin on a small circle track tonight, set up on trans am.
T56
koni yellows on stranos
27540r17 front 315/35r17 nitto 555s
stock sway bars
questions i had were
would it be better to run a softer aetting on fromt konis or stiffer, i had them 3 clicks from the softest setting last week and turned close to the same time as last year on stock suspension, was gunna try 5 turns tight instead of 3, would it be better to have the pass side shock stiffer then driver? (all left turns)
what psi would u recommmand tires, was told 26psi front driver, 32psi pass front and "around" 28-30psi on rear tires, u do have to launch from a dead stop drag race style then u start doing laps
any other thoughts or suggestions are apprtiated!
thanks!
Old 05-16-2013, 02:54 PM
SPDKNGG's Avatar
T56
stock sway bars
thanks!
You need to do your homework and understand the physics involved so you can make the appropriate decision on what best for your setup.
I would start here..great info
http://www.circletrack.com/chassiste...s/viewall.html
Old 05-16-2013, 02:56 PM
SPDKNGG's Avatar
This is one of my favorite articles and explains a lot and exactly what you need to understand. hope this helps you.
http://www.circletrack.com/chassiste...p/viewall.html
Old 05-16-2013, 03:56 PM
ToxicWS6's Avatar
thanks!, i read some of the first link and seemed like good info, probably read them both when i have time tonight or tomm.
trying to do the most i can with out sacrificing the ability to DD it too much, i did take .7 secs off my lap time though by doing what i did above. plan on reading the links and messing with it more this weekend before next wed and see how it does
Quick Reply: circle track questions quick ish
