How to pick a motor
Old 07-08-2013, 07:24 PM
31-5window's Avatar
Default How to pick a motor
I would like to use a LS motor in my current project which is a 1950 chevy car I want this car to be a driver. So the question how to decide what gen motor pros and cons please was thinking 5.3??????????
Old 07-12-2013, 12:30 PM
2000PewterT/A's Avatar
Any LS motor will work, for budget you can't go wrong with a 5.3. I will be swapping one in a 70's c10 for my next daily driver.
Old 07-12-2013, 05:55 PM
D14HUGGER.ORANGE's Avatar
Yes 5.3 would be perfect power plant. it will make awesome power with bolts on's. look for a L33 5.3 because it has the 799 heads.(243 truck heads ) With a good flowing 799 heads will leave you with the 5.3 you can also run boost if you would like on stock bottom end and get you well past 500+ hp on stock bottom end. The L33 came on the 05-07 silverado/Sierra
Old 07-12-2013, 06:04 PM
Yes 5.3 would be perfect power plant. it will make awesome power with bolts on's. look for a L33 5.3 because it has the 799 heads.(243 truck heads ) With a good flowing 799 heads will leave you with plenty of options with bolt on's to make good hp/tq. Choosing the 5.3 you can also run boost if you would like on stock bottom end and get you well past 500+ hp on stock bottom end. The L33 came on the 05-07 silverado/Sierra. Lq4-lq9 6L would be a good motor if you want to stay n/a if you want to build a budget 402-408 stroker the 6L block would probably be the best. With the amount you would pay for a ls1-ls6 or ls2 you can build a badass stroker or make plenty of power with bolt ons either the 5.3 or 6.0 block.
Old 07-12-2013, 07:09 PM
Blackpanther99's Avatar
5.3 with 243 heads Planning on boosting it? Or it gonna be N/A?
Agreed with posts above^^^
Old 07-12-2013, 07:55 PM
ULTIMATEORANGESS's Avatar
Smile
id go ls2 or bigger but thats my preference.
Old 07-12-2013, 09:37 PM
garygnu's Avatar
a 5.3 ls motor would work great .do you plan to use a ls fuel injection wiring system ,or do a carb set up ?elderbrock sells a stand alone intake ignition system .the truck intake makes good power ,you mite find a 5.3 for $500.I believe painless wiring has a engine harness for ls transplants.
Quick Reply: How to pick a motor
